Empty Toolpath?
Why do I keep getting “empty toolpath”??
Geometry needs to be wide enough to allow the tool — at least 10% wider than the endmill at its narrowest point.
Try using a smaller tool?
Or post the file and we’ll gladly look into this with you.
Thanks for quick response Will. Trying to make some new holdowns, I am trying to create 1/4 inch holes. I will do a bit change to 1/8 inch. Thanks again
make them just a hair bigger than 1/4", and then CC will generate a toolpath when using a 1/4" endmill
Thanks for your advice, I will give that a try in the morning
I suggest you get some washers to go under your hold down screws if the hold downs are made of wood. If you make a recess on top of the slot then make the recess big enough to get a washer in the recess to not tear up your hold downs.
I did put in a recess for washers, but thanks anyway
