Whenever I need to resurface my spoilboard, I need to remove the bitsetter (as that would be … resurfaced as well if I don’t
). That means re-running the machine setup to remove the bitsetter, doing the resurfacing, and then rerunning the setup again to re-enable the bitsetter. I would love to get the “bitsetter enabled” check box back for quick jobs like this, please!
There is a button in settings to disable Bitsetter. You only need to run the wizard if you want to change where the BitSetter is located.
I could have sworn that checkbox wasn’t there five minutes ago, but that would just dig my hole deeper. I’m an idiot, thank you for your quick answers! ![]()
