Is the OpenBuilds Modular 1010 enclosure sized appropriately for the HDM? The dimensions are:
Inside Dimensions: 46" W x 46" L x 29" H (1180mm W x 1180mm L x 740mm H)
Outside Dimensions: 48" W x 48" L x 30" H (1220mm W x 1220mm L x 761mm H)
From the collateral material I’ve seen published so far it would be wide enough and definitely tall and deep enough but I’d like confirmation from someone with a machine or a CAD model. @WillAdams@Julien@wmoy
Speaking of CAD models, can we expect something soon to begin our own development?
It has been a while since I modeled this, I should point out the machine is not even on both sides, and I designed my enclosure so the middle of the spoilboard is in the middle of the front of the enclosure, so the machine is positioned slightly to the right with a gap on the left side. One could potentially have a smaller inside dimension if they did not mind the machine bed not being centered in the enclosure.
