Enclosure Panels
I started an OpenBuilds enclosure build for my HDM and am shopping around for panels. Anyone have any suggestions on materials to use, or not use? How important are the anti-static properties of the material being used? Saw some cast acrylic sheets advertising as being an anti-static variant, wasn’t sure if that was just marketing or if it’s helpful or recommended for working with certain materials (ie: carbon fiber).
HDPE? the Nomad uses it, should be a decent choice.
I like polycarbonate… It’s not antistatic by nature, but I haven’t heard that that’s an issue.
If you’re considering HDPE, then I’d just go with plywood as it’s a cheaper material that you can’t see through.
