Post back if you figure it out. I cut ALOT of cherry and get a ton of chatter, pretty much always, i’ve played around with speeds a ton and never been able to resolve it. I mostly do Cherry, Ash, Oak and Walnut, 99% of the time that’s all I cut.
I ran some tests last night at 100ipm vs 35, and smaller doc, under .1, seemed to work better to the point of me sticking with this faster speed with smaller doc to get a better finish with less chatter
I run a small DOC as well, i’d have to go look, but i don’t cut more than 1/8"
for sure. But never sure if that is good or bad on the end of a longer bit, i usually run at least 1" cutting length bits.
I usually run like 60/30 or 80/40 to get a decent finish for less sanding. Less tear out ,especially in cherry.
