Ending Position
I would like to be able to have the gantry move to a different location upon completing a project. In a multi step project a lot of time is wasted for the gantry to move all the way to the back middle after each file completes.
There are three ways to control this:
  • for X-axis positioning you can put a very shallow drill operation at the X-axis coordinate you want the file to end at as the last operation — that will then be moved to and the machine will move back from that position
  • If you extract the G-code you can edit the file to have the desired behaviour
  • If you have Carbide Create Pro, modify the post-processor, see:
https://my.carbide3d.com/faq/create-pro-custom-post-processor/
