I have tried to mill text into wood by using the #122 (1/32" Square Endmill), but can’t seem to get it to work with any text smaller than about 1/4" in height.
Any suggestions for smaller text?
I just had very good luck with this one.
For a square endmill the narrowest feature of the text needs to be 10% wider than the endmill diameter.
Better to use a V endmill and a V carving toolpath:
Great! Thanks for the info.
Thanks! I’ll try that. How small can the text actually be?
That’s a good question (how small can text be) — this depends on the mechanical resolution of the machine and the accuracy and precision it can move at – backlash and so forth become issues at small sizes.
Not a V engraving, but I did a diamond-drag engraving text on my Nomad and achieved quite small text (unfortunately, can’t find the piece of acrylic at the moment, and my phone reset itself when I was cutting the grass a while ago, so no photo).
I would suggest making a test in a piece of scrap to determine just how small you can achieve.
When I view the “show simulation” it will not complete the entire letters if the text is too small. (using the 1/32" end mill, which to me is a very tiny mill) It just seems that I should be able to create text smaller than 1/4" high with this tiny mill.
It is not the height but the width of the letter. If the simulation does not show properly your bit is too wide.
It just seems like the 1/32" bit is small enough to do some pretty little text. I have also tried the #501 engraver with the same “show simulation” results.
I’ll give the v-bit a shot.
The #501 is a vee bit. The preview for a vee bit does not render properly except for vcarving tool paths. If you try contour cuts like pocketing the simulation will not render properly and/or cut properly
