Engraving metals
Would my shapeoko pro with mikita router be able to engrave metals? What bits work best and settings?
First one is 304 stainless:
planeform. com/products/sr-71-black-bird-bottle-opener
Then what claims to be brass:
amazon. com/dp/B0BT5794FJ?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
And what I believe in powder coated aluminum:
Lastly 304 18/8 stainless steel:
https://www.yeti.com/drinkware/barware/21071504291.html
I probably have to put my text vertically on the hand warmer and flask since there’s no flat surface like the other two items… right?
For the stainless a spring loaded etcher like the McEtcher
For the brass an engraver tool.
I’ve etched curved surfaces, but I had to use a different CAD/CAM software that would project a path onto a curved surface.
As @Tod1d mentioned the McEtcher is good in stainless.
For powder coated aluminum like gun parts, I use a very small tapered ball nose bit with a radius of .25mm. This is a pretty fragile bit so I sweep my project in X and Y direction with a dial indicator and adjust as needed prior to cutting.
When you say engraving tool does that mean an engraving bit like Amana Tool 45771-K?
The Amana 45771 is a tool intended for woodworking, it is not for engraving metals:
Here’s the MC Etcher from Carbide 3D.
the #501
the #502
No, more like the #501 #502
Thanks for clarification, new to all of this!
