Engraving On Shapeoko Pro
I’m looking to try and “engrave” stainless steel with my Shapeoko Pro XL. A couple of questions:
  1. Is it possible?
  2. If so, what bit to use?
  3. What feeds and speeds?
  4. In addition to engraving I want to cut them out. What bit if different from #2 above?
  5. What’s the best method for holding it in place while carving/cutting? It is very thin.
Thanks!
How deeply do you need to mark?
The M.C. Etcher works well for this:
As noted above, I made a custom fixture to hold the part.
Thanks Will. I will look into the etcher.
What about cutting the profile?
Cutting out wasn’t relevant to what I did.
You’d need a suitable carbide tool for cutting steel — there have been a couple of posts on it:
https://community.carbide3d.com/search?q=stainless%20steel
