I seem to be having issues in two parts.
One operation (the lines) I am doing a contour with no offset using a 60 degree v cutter. I tell it I want to cut to a depth of 1/32". However the cut ends up almost .1 inches (see picture 1)
The second operation (the numbers) I do the traditional vcarve, 1/32" depth. However the bit looks like it went way deeper than that. Se picture 2.
I used the same bit for both operations. Is it possible I simulated the bit wrong when entering parameters or something else I may be missing.
Thanks
