Is there a way to enlarge strokes in Carbide Create? For example, in the right pic the circle is thicker than the circle on the left. Thanks in advance.
You could perform an inner and outer offset to get the thickness you want in CC.
Vectors are more concerned with the paths. Paths have no thickness. If you need to be thicker than your endmill, you could do as @macklebee suggests and fill the space between two offset paths.
