I found a bottle cap STL on Cults3D.com
I’m pretty sure this STL will be usable in CC Pro, but I’m sorry that I can’t explain how. Perhaps @WillAdams has a demonstration already available?
Once the cap was in my project I did a 3D roughing with a .125 ball nose .0625 depth, .0125 stepover, 12,000 RPM 40 IPM feed and 20 IPM plunge. The finish pass was also with a .125 ball nose with the same parameters as the roughing pass except for the stepover which was .010. This resulted in almost no sanding, perhaps 2 minutes on each piece with 320 before the poly coat.
For the text I searched the the Fallout Wiki fan site and copied an image from there. It took a lot of modification to the curves to allow a .0625 end mill to fit within the confines. So it’s a close representation, but the steely eyed readers here have already spotted the differences I’m sure.
Feeds and speeds for the text cut were: 1/16 end mill, .0252 stepover, 12,000 RPM, 25 IPM feed and 15 IPM Plunge.
Here’s the DXF of the text and outside cutout:
NukaCola.dxf (373.8 KB)
Now lets all go enjoy a nice Quantum!
