Hello, I am using a Shapeoko 3 XXL and have been getting the message “GRBL error: G-code words consists of a letter and a value. Letter was not found.” every time I try to home the machine. I have fully updated my carbide motion to the latest version, but it still, will not work. I have also tried it with different computers but still, get the same error. I think that the problem might be in the control board, but I have no idea how to fix it. In earlier versions of carbide motion, I was able to get around it. I would run the tool path then stop it and jog it to the origin, then hit resume on the control panel. With the new update I have to hit initialize machine and that is when the error pops up.
Sounds like EMI to me
I suffered the same this month but mine was happening during a carve
I rerouted my cable but did not help
It happened every time on the same carve at the same place so I turned my router speed down and it stopped
This however will not help if it’s happening during homing
One way to stop EMI is to wrap your cable around something round at least eight times ( if you ha e enough cable, this will make a choke that should stop it, better still wind it it around a ferrite ring
Yes, one can reflash, but usually the software is a binary thing, either it works, or it makes exactly the same error in exactly the same way, at exactly the same point each and every time.
Cue Edsger Dijkstra intoning,
Anyone who believe computers are capable of generating random numbers is in a state of sin.
