I’ve had my machine now for a year or so and have never had any issues with the coding part. This morning I was working on a new project and when I try to run the file in Motion I keep getting a Grbl error that says “a Gcode word was repeated in the block”.
Having never received this message before, and not being a programmer, I’m not sure what’s going on. I use Carbide Create to make my files and have had no issues to date.
Any ideas about what is going on or how I can get the file to run properly?
It gives me an error within the first minute of starting to run the program. First time I ran it the error message came up in 10 seconds. I shuffled the order of the pathways and tried again, which is when the error message came up at about the one minute mark.
First, reboot. Then, please try testing the file in check mode.
Go to the MDI and send
$C
then send the file — Grbl will process the file without moving the machine — if you still get the error and your computer OS is fully up-to-date and you are using current versions of Carbide Create/Motion please send the file and the file which made it in to support@carbide3d.com and we’ll do our best to look into this.
