Error Code min time
Need help identifying this error code I have been seeing lately. “Move < min time” press resume to continue. Any help greatly appreciated.
CNCJS and Carbide Create
Brian
Which machine / firmware?
This essentially means that the move in the gcode is very tiny & at the feedrate you are travelling it would take less than a threshold of time to make the move, not giving the machine enough time to process the next move. I think the error comes from the firmware, and CNCJS is just passing it on.
Here’s a post on github that talks about it. Error Code 202 Issue. Pausing during file. · Issue #231 · cncjs/cncjs · GitHub
If you slow down the feedrate, does the error go away?
Thank you Tod1d, Info was very helpful!
Brian
