Error: GRBL Not Found on Device
Does anyone have a fix for the “GRBL not found on device”. I’m using a Shapeoko 3 XXL and can’t even run the machine. I have searched the forum but people are not posting what they did to fix it.
Try this
Download all the latest versions of Carbide Create. and Carbide Motion.
Once you do this leave the machine OFF (not powered up) open Carbide Motion and you should be prompted to (Setup a new machine) or select the Setup New Machine green button at the bottom of the Carbide Window. Follow the setup steps and be sure to select the settings for your machine and any options you have.
This should may your problem.
Anthony
Saw your ticket on support and we will do our best to work through this with you there.
