Error: Only C2D files from carbide create v7 are supported
I’m using motion 618 and create 757. I didn’t update anything and had no problem with the files before??? Why am I getting this issue?
Where are the files being written to/read from?
Using what permissions?
Is it a local drive or network?
What is the filename?
What is the compleat path?
Upload the file here to check? (Note that it is possible File | Save as V6 File)
I shut everything down then saved the file again and it worked. So odd because I’ve cut this file over a dozen times already and never had this happen before.
