I’m a refugee from Fusion so forgive me up front. I’ve set up my stock perimeters 24"x 5.625". Select a Square vector and draw it within the stock dimension. With the square vector selected I go to Parameters to re-size and after typing new width dimension I get Error ‘Radius’ must be between .001-1000in. I’ve gone back and forth trying different things and still get the error. This “Radius” field even stays grey, can’t change it.
No, I’m drawing from scratch in Carbide Create. Perhaps my reference to Fusion was confusing. I’m used to extensive drawing in Fusion and just frustrated to see such an error at basic command.
Please click on the corners drop-down “Square” and choose “Fillet” — that will make the Radius field editable and change the number there to be 0.001 or larger.
