Errors from KiCAD 9.0.7
I’m getting input errors when trying to import a Gerber from KiCAD 9.0.7:
  • GerberParser: Unhandled macro primitive type: 0Rectanglewithroundedcorners
  • GerberParser: Unhandled macro primitive type: 20,1,$1+$1,$8,$9,$2,$3,0
I will go old-school and use a DXF output from our tech for the isolation routing–it can be done as a single-sided board with a single blue-wire to replace the one backside trace. Zipped front copper file attached.
If Copper is still being supported could you look into it please? Thanks.
11581_10_LED_BD-F_Cu.zip (1.3 KB)
