I am curious if there are any examples of people replacing the angle iron supports underneath the work table of the Shapeoko 3 XXL with some sort of 8020 Aluminum extrusion?
I would like to do this because the provided supports are not stiff enough and bow and bend under force.
I feel adding some much more robust supports would really help it out as well as make a more modular approach.
If not I will be sure to share what I come up with!
Many people just put a rigid foam underneath which helps with sagging but doesn’t help with resisting lifting due to cutting or clamping forces.
I simply put plywood fillers under the steel straps, drilled through and bolted the whole assembly down to the torsion box it lives on. No more sag, much less vibration.
I started with CNC in November 19, I ordered the XXL S3. Upon assembling I noticed the frame only had one thin cross strap in the middle, I ordered a 1/2 metal spoilboard from Ohio Diesel thinking that it would strengthen things up and all was good. Over the next year I had un-explainable depth and edge issues I could not figure out, thinking I was making mistakes or V wheels were off or whatever. What was happening is when I would bolt stock down with clamps, the bolts would pull up on the surrounding area enough to cause measurements to be off. Probably not noticeable to most but I try to gap pieces .0075 etc. to fit together, and was constantly having issues.
When I ordered my SPro’s I was very happy to see regularly spaced frame rails, and since all my models are setup for an aluminumn threaded spoilboard, I designed and special ordered 3/4" boards for my Pros, and the rigidity has eliminated all my wtf moments on gapping parts fitment properly. The S3’s I decided to keep and mod, are both setup with the 80/20 frame with 1/2" threaded aluminum spoilboards, and it has a strong cross section frame and base with lots of attachment bolts, and does not flex like the bent steel S3 frame did when I was tightening clamps on it.
CrookedWoodTex
(Tex Lawrence (Don't Mess With My Texas!))
8
Thanks! Now I know that your spec is well within my tolerance. I don’t do any metal work on my machine.
