CM - 622
I have learned to check the gcode before starting a job using NcViewer. In this project I am using CM to export Gcode from a CC764 project for that review.
The operation is a Contour using a #502 engraving bit on cast Acrylic. The DOC is set to 0.010 inches with the max depth of 0.040. CC shows multiple depths of passed as expected
The exported Gcode from CM only exports the first pass.
Has anyone seen this ?
However, I was able to easily overwrite a C2D with the g code. CM 566 actually gave me the default name of .cd2 and asked if I wanted to overwrite it. This is no doubt what was happening to a couple of forum posters a month or so ago. If the current version still does this, it should probably be changed.
