Would it be possible to get an option to extend lines in carbide create? Also I would like to see a function that when you realize you made a mistake in the file and stop to change file to not have a crash?
There are several quick workarounds. Scale is the quickest. Or copy/paste the line & move the new line to the end of the original line.
If you can let us know the specifics of the crash we will do our best to work through it with you.
If on Windows, be sure to send in the Bugsplat report and include your e-mail:
It’s not a crash of sorts. I failed to explain. Example the other day I loaded a file and got ready to cut. Then realized I had a loose clamp so I paused the machine and the only way I could continue was to re-initialize then machine and start over.
