Extra lines in Grblcontrol
I got a laser for my CNC machine. So for now I’m using ‘Laser GRBL’ to learn and do projects. every time I try to get text from the files the text is there but also path lines the a spindle would follow. How would I eliminate the lines? I’m new at this and just learning.
You’ll need to tell GRBL on the Shaopeko controller that you want to use Laser Mode by sending $32=1. $32=0 to return to CNC.
I’m not sur how to do that. do you mean on carbide create or laser Grbl?
Take a look at this page. It should help get you set up.
