I plan to mill this such that the ‘&’ is 0.2mm lower than the other two letters. I can create tool paths for the contours, but how do I create a tool path to face the ‘&’ to a lower height? Also should this be the first or the last step?
https://a360.co/2LgLWlV
Many thanks! Gunter
It’s basically the same process. Select the face, then select “face” or “pocket” and it should be selected as the faces to mill.
@mikep - great, thanks!
