I’m a complete beginner so sorry if I get the terminology wrong.
I’m going to be using my Nomad 3 mainly for milling aluminium, and in most of the videos online of other machines milling aluminium they use a big “face cutter” to completely flatten the top face of the billet stock to start with. Is there anything like that available for the Nomad? I saw this but it says it is only for wood: McFly Surfacing Cutter - Carbide 3D
If not, I guess you just use a normal flat bottomed endmill to do this?
The Nomad 3 has a stronger spindle motor than the previous Nomad, but it doesn’t have the power to use anything over 1/4" diameter tools effectively. On my Nomad 883 Pro I only use a 1/4" endmill for facing. Everything else is done with a 1/8" tool or smaller.
The McFly Cutter is also not designed for aluminum.
Yeah I’m aware I need to use cutters with a 1/8" shank, but that doesn’t answer the question. Maybe I should reword the question to: Are there any facing tools similar to the McFly but in 1/8" shank variety? (I did search online for some but wasn’t sure if the lack of results was just because I’m using the wrong terms etc)
