Right now all pockets are cut from center to outside. This is fine for most use cases, but I have one case now where Outside In pocketing would work better.
When removing the back part of the plug of an inlay, the outside edge may not be supported in any way. With Inside Out pocketing, on the last pass the perimeter of the plug can come free.
Outside In pocketing would remove the perimeter before it could be freed.
