Feature Request - Way to determine how deep a VCarve will actually go
VCarves (not Advanced VCarves) don’t have a defined depth - the advice for the ‘depth’ parameter is to use ‘t’ as a value to limit the VCarve to the depth of material.
I would like a way to determine how deep a VCarve path actually carved. This would be useful to determine how thick a piece of stock is needed for a given project.
I couldn’t find anything in either CC or CM. The visual representation allow one to guess, but not accurately.
The only way I can think of for today would be to set a large ‘depth’ value, then try successive smaller values for the stock thickness until the carve punches through. Again, not very accurate, especially with very acute V bits.
Draw it up in profile?
That’s what I always do.
That works if you know the width at any given point. To know the total depth, you have to know the widest point, and that can be tricky for anything complicated. The math itself is easy, no problem there.
How deep will the lettering go? I guess the bowl of the ‘R’ is the widest point, maybe?
Or the computer could figure it out exactly for me.
The new v8 beta switches to Advanced V carving, so one can control/set the depth as desired.
I’m using V8 right now, setting a limit doesn’t solve the problem. It just gives me a different problem.
I don’t want to set a limit, because I don’t want flat bottoms on my letters, i.e., I want what a V7 VCarve would give me. On V8, you’d get this by setting a depth greater than you expect it to be, and then you still don’t know how deep it will go.
Post it & look for the lowest Z ???
Or build it into the post…
X3.0536Y4.3516
X3.0526Y4.3758
X3.0518Y4.4000
X3.0513Y4.4244
X3.0512Y4.4488
Z0.1969
M05
M02
(Low Z: -0.118)
I would find a feature like this useful as well.
