Okay, I finally got my Shapeoko XXL and have tested a few projects. I’ve had good success so far, but I’m just trying to understand a little better. I read quite a few documents, used Carbide Create for a while, and watched a bunch of videos before starting.
First, I get that feeds and speeds are kind of a personal preference to an extent, but there are clearly some general guidelines and starting points as well. So, my question/confusion is the huge variance between recommendations from the Carbide 3D direct sources. Take hardwood for example using the Makita settings and a #201 ¼ end mill:
• Carbide Create Default: plunge: 12 IPM, feed: 60 IPM, RPM: 18k, DOC: .04"
• YouTube #MaterialMondays: plunge: n/a, feed: 75 IPM, RPM: 18k, DOC: .06"
• Wiki/Feed & Speed Chart: plunge: 30 IPM, feed: 65 IPM, RPM: 19k, DOC: .22"
My question is, there is a HUGE discrepancy on some of the figures between the three Shapeoko specific sources I’ve found, especially on the DOC, which is huge on some materials. Obviously I can test out the material, but I really don’t understand why the Carbide Create tool library has such a huge variance from the feed & speed chart. My question is, where should I lean more towards when starting–the videos, chart, or built-in carbide create defaults?
