I was wondering if anyone has taken the feeds and speeds from Carbide Create and placed them in an Excel (or other spreadsheet) format.
I thought it would be nice to have this information in an editable and expandable format (especially as I add additional bits). I have been meaning to do this for some time, but haven’t gotten around to it.
I thought I’d ask before I started, as someone else may have a better way of organizing this information than what I have in mind.
You can duplicate the official feeds and speeds so that they are in an editable .csv file which you can then edit w/ a spreadsheet (just be sure to re-save as a .csv) — access these files using Help | About | Open data directory — they’re in the Carbide Create/tools directory
EDIT: The path provided is the default location where Carbide Create stores these files. Also looks like it will check there when you start the application for the listed files (a.k.a. Tool Libraries). For example if you edit the .csv file adding tools to it and move it to this location the next time Carbide Create is opened the .csv (tool library) will be known and will be listed when you browse the tool libraries from within the software.
