I am creating a Modern Adirondack Chair and all the parts cut properly except the arm. The arm is useable but it is not cutting according to the file. Can someone look at this and see why it is not cutting according to the file. The Arm is smaller than specified.
swan_second_arm.c2d (111.0 KB) swan_second_arm_201.nc (21.4 KB)HI Guy,
Both of the arms are open vectors. Select each vector, one at a time, and use the join vector button.
After the vectors are closed the outside right tool path looks a bit different.
Man, that’s a real stumper there.
I had to drae these from poly lines. I had joined on the other pieces. Guess I forgot to join.
Thanks. The pieces made are a little short but useable.
Lester thank you. This is the second time an open vector has snake bit me. All the other parts I used the join vectors. Guess I forgot to do this one. I am partially color blind and some shades look the same color to me. Red and magenta look the same to me.
Thanks again.
