Laptop died so reinstalled Carbide on new laptop.
I go to open various old project files and it appears to load except there is no project displayed on the screen. Also, the stock sizes on all projects open at 0.9" X 0.9" with 0" thickness and 0" retract height.
Anyone have any idea what is going on and how I can recover all my projects?
What version of Carbide Create did you have on the old laptop? Which verison did you install on the new one?
What kind of laptop(Mac/PC)?
Are you opening the files from within Carbide Create? Or trying to load the files directly from a File Manager window or desktop? Older versions of CC would not load project files that way I distinctly remember - I believe that was resolved in v7.xx.
Machine is a PC
I don’t know what the previous version of Carbide was and that laptop is toast so I can’t check.
I tried opening files both ways, from within Carbide as usual and also from the file manager. Same result with both attempts.
Good evening I had the same problem. Do not emphasize above letters or special characters in the title of your backup file. There are a lot of them in French. Since I no longer put an accent everything is fine. I hope this will solve your problem.
