I’ve been wresting with my XXL for a month or so. Most of the basics are coming to me and the process has proven enlightening.
I use my home desktop computer in the evenings to design and save Carbide Create files. GCode files and CC files are both saved to a USB and I take them to the wood shop. This gets plugged into a laptop and off we go. Computers are MAC based.
I’ve ordered up some new Amana Bowl bits (45984) and am wondering if I need to enter the bit parameters onto the shop computer. Is there a simple way to transfer the new bit data to the shop computer? Does it matter? My shop space is not conducive to computer design work and is a couple of miles from the house, so the file transfer drama is minor yet very real.
I have pretty much the same setup, except the shop (garage) is only 40’ away.
I have both CC & CM in the shop, but my tool libraries don’t match up. i.e. I don’t need the tool defined on the shop laptop to run a program on the machine.
One thing I haven’t figured out yet… If you use a Carbide 3D tool in your program, the tool prompt in CM gives you a robust description, with a T201M6 “Load 1/4” End Mill"
But if I create my own tool, and give it another number, for example T1M6, All I see is “Load Tool 1”
I suppose the default tools in the library are also indexed in CM. It doesn’t look like the text string is in the gcode file.
I’ve quit using thumb drives & just post all files to a temp folder on my google drive, but I have Wifi access in both locations. I do usually include the .C2D file in case I want to review it in the shop, or make changes.
That’s all good, but doesn’t answer the question r hand. I suspect one is in the offing…
I have had very good success using Dropbox to synchronize the CNC files between 2 computers. I’m just using the free version, haven’t had any problems. However, that of course requires network access for both computers.
With a bit of work b(at least on Windows), you can even get use Dropbox to share the tools database (really, just a CSV file) between both computers, so when you add the tool on one computer, it will show up on the other. Mac probably also has a way, just not a Mac user.
Or, you can just copy the tool databases manually of you like. Help / About / Open Data Directory will show you where CC keeps its files, including the tools you’ve entered.
I thought that part answered your question. You don’t need the tools on your shop computer.
If you want them there, at home select Help → About → Open Data Directory, Select Carbide Create, then Tools, and copy the .csv files (one for each tool library you created) and transfer them to your shop computer.
It seems to me that once I have the Code saved, the tool is already called out in the code. Sometimes I need to adjust the file in Carbide Create and then it becomes an issue. I’m still new at this and often feel as though I am standing in the doorway of a large library.
