I created a rectangle I then selected fillet all in the transform box. But now when I select the rectangle it has no parameters option. I was wanting to look at different corners but I have no option to try out other corners for example chamfer, dogbone. I created another rectangle and did not use the fillet all option instead adjusted the corners in the parameter box and that allows me to keep making modifications. Is there a way to get the parameters option back or should I just never use fillet all since it limits what I can do later?
Once you modify a rectangle (or circle) [rotate, offset, fillet, trim] , it is no longer a primitive object. It’s just another curve. The Fillet All feature works on many shapes that are not rectangles, so it still has value. If you think you’ll need to modify the rectangle, use it’s parameters where possible.
