Is there an easy way to FIND open vectors? I import a DXF and get the message stating that the file contains open vectors that are not suitable for v-carve or pockets. It says to use the join command to close/merge the vectors.
How can I locate these open vectors easily? I do not know where the join command is.
Select the areas you want to join, that may be everything. Then choose the join vectors.
An alternative is to zoom in to the extreme and look for unjoined lines. That is tedious but necessary some times.
