Having a problem. After a design I save a mybwork as a c2d file. I try to open it up just to check it and it’s not there the only options the upload is giving me is def or svg. If I look at the file folder outside of CC it shows everything just fine. How do I change settings to be able to see the c2d files when trying to upload from CC. Thank you it’s a new computer so assuming it’s a setting on the computer but for the life of me I cannot find it
Hi Shawn,
I think you may be confusing the “Import” action (which is used to load a vector design element INTO a design, from a DXF or SVG file), and the “Open” action which should allow you to open a previously saved c2d ?
