Watched the demo videos and gave it a try. Need to seal it and paint it but think it came out Freakin’ Awesome!
that came out great.
looks very sharp
you crushed it! nice clean lines
So good! how will you finish it?
Great job! So that whole sign was done with a Vbit and advanced v carve? What depth did you do? Do you have to have the bit setter to use?
Carve depth was 1/8 inch. Clearing path with 1/4” endmill then v-carve with 60 degree bit. Yes, I have bit setter and it worked great!
Sealed, hand painted and filled with phthalo blue resin. Imperfections in the pine let the resin seep into spots but otherwise turned out excellent
