My whiteside 6210 with the belt driven z axis will go through a 1” supplemental spoilboard by at least 1/2” which is fine.
I am now really concerned about cutting down to the spoilboard with 1/8” endmills for full depth pockets or profile cuts. These also typically only have a 3/4 shank and a typical cut length of 1“. Will these work with the Z-plus?
Yes you could do that… but just measuring from the bottom of the collet to the top of the wasteboard when full descended will be good. Better yet would be to measure from the bottom of the x-axis extrusion to the bottom of the collet… that would be definitive but more tricky to measure.
I have a 1/2” aluminum base board with a 1/2” spoilboard to maximize the z cutting depth. What is you baseboard and spoilboard thickness?
Another possibility is that the combined length of the Carbide3D router barrel to the bottom of the collet is shorter than the DeWalt router that I use. I just measured mine at 5.4”.
As I say - I have plenty of z-axis travel with the belt drive z axis… so I have never thought I would have any cutting depth problems until I saw your pictures with the z-plus. I was expecting to buy that upgrade when it became available…
Fully lowered, the collet is 1 1/4" from the spoil board. It also looks like the 1/8" endmill is about 1/8" shy of touching the spoil board. That is with 1/4" of the shaft in the collet. I would think it might be safe to pull the end mill down more, but I would think there would be a risk of breaking.
My board is the standard baseboard that was shipped with the Shapeoko 3 xxl and my spoil board is 3/4" MDF. I can fix this by adding another 3/4" board on the baseboard, then putting the spoil board on top. This is my first CNC, so I don’t have plans on working on anything with depth (like boxes or real thick stock). I just wanted to check to make sure it wasn’t user error.
You certainly need more than 1/4” shank in the collet for safety and I would expect unacceptable runout with so little of the bit supported by the collet even if it was safe.
With my z-axis descended fully, the bottom of the collet touches the spoilboard even though my combined baseboard and spoliboard thickness is 1”. Yours must be thicker I assume your base board that come with the machine is either 3/4 or 1” thick.
Kinda hard to see if the minimum (original)wasteboard-to-collet distance is the same, you may want to get in touch @haluski or @annmeganm so that they measure it on their machine, to confirm this is just the “expected” Z-travel situation.
I just signed up to post on this exact question/issue. I thought I did something wrong, but apparently there isn’t as much downward travel with the Z+?
I have the Whiteside 6210 and and it can BARELY touch the supplemental wasteboard (3/4" MDF, on top of the provided main base), with hardly any of the shank in the collet. Definitely doesn’t scream “This is secure, go ahead and run it!”.
What are the options here? I don’t really feel like replacing my supplemental wasteboard ALREADY with a piece of 1" MDF – not even sure where I can find that. I’m not that familiar with 1/4" bits, let alone 1/8" bits, so if they are typically even shorter, am I going to have no other option than to get a thicker wasteboard, or possibly double up?
Can anyone confirm if the Dewalt or Makita have a longer “reach” to them than the Carbide router, or is this just a Z+ issue, period? I have 2" from the original waste/base board, to the bottom of the tightened collet nut.
Nope, nothing installed upside down. Z axis doesn’t travel down far enough.
I went ahead and cut another piece of 3/4 MDF and sandwiched it between my stock board and spoil board. I was able to finally flatten my spoil board with the Whiteside 6210.
All is good now. I’m sure in the future when I want to work on taller items, I will have to remove the sandwiched board . So I can have the clearance.
Thanks to everyone who chimmed in and provided guidance…
Wish I knew this before drilled and installed 150 threaded inserts…
Guess I will go get a 1/2 piece of MDF to sandwich between.
The carbide router is dropped all the way.
I am at 1.25" with a 0.76" MDF supplemental wasteboard.
I cant flatten my wasteboard with the whiteside 6210.
Ouch. I’m brand new to CNC, but I went the t-track route. Seemed a LOT easier, cheaper, and less time consuming to just drill/countersink 8-10 holes in (5) pcs of MDF and screw those to the original wasteboard, sandwiching some t-tracks in between them.
The big question is does the new z plus travel as low as the standard one? I’m planing on making the purchase when available am I going to have to add another waste board in order to us it.
I built my shapeoko 2 weeks ago…these are the pictures of the 201 bit and where it reached on carbide mdf. My post on z axis and wasteboard After I put a temporary spoilboard down the bit reaches fine. I will say that I like the fact that you’re required to have an additional spoilboard fitted on to your machine (as a noob) as I would have ruined the factory boards. The only thing I can suggest is that Carbide advertise this fact a little bit more. It’s not huge thing but it’s an easy fix.
Yes indeed, you should make a spoilboard to go on top of the factory supplied baseboard. And yes, a 1/4” shanked bit like the #201 should reach it.
It seems with the z-plus that it does not come low enough to use a spoilboard surfacing bit because the 1/4 shank is shorter.
More importantly it seems that any bit with an 1/8” shank will not reach the additional spoilboard at all. This means you cannot cut full depth pockets or profile cutouts at all with just one additional spoilboard.
The only solution seems to be is to have TWO additional spoilboards on top of the factory board to bring the height up so you can surface the top spoilboard and use 1/8” bits successfully… like when cutting through 1/4” stock which often is needed.
So it seems you need to add around an extra 1 1/2” height to use successfully in those circumstances. This also means that it will reduce the maximum thickness of stock that can be put in the machine by some amount that can’t really be worked out without seeing it.
I hope that Carbide3D will make this clear. Obviously they know all these dimensions and limitations… and should publish on the website to help guide the buyer to the right purchasing decision.
I would like a definitive answer to this from them (@Luke) as I was hoping to buy a z-plus when they become available… but this additional height required has been a surprise and may now adversely affect my buying decision.
I think this issue is only just being noticed because the z-plus is at the moment only going on new machines to typically new users who have not yet realized this shortcoming like the OP and some others.
May I suggest putting in a 800W G-Penny spindle in instead of a router. You’ll have plenty of additional length to reach the spoil board and enjoy the quiet in the shop too. It fits in the stock mount with the Makita adapter.
You might have to wait a while for it to ship from China at the moment.
I am in the process of selling my Large CNC router 48x48 with Mach4 and 2.2 kW spindle driven by VFD. Been doing this for 20 years or so. Looking to get the XL for move to retirement residence. Oh I am new here.
My guess is #1 a design flaw or can the router mount be remounted to a another set of holes in the back plate.
Thought on ball screw mounting, why can’t you just remount the Z motor and add your own ball screw and nut?? Like the last two machines I owned had?
