Flip Cribbage Board
I am trying to make the cribbage board from CutRocket that has the deck of cards in between two pieces. Have no problem making the cuts until it comes to cutting out the top piece that you have to flip over once you have all the pegs done. What is the best way to get the them to line up once you flip it over. Any tips or tricks I seem to be off. Do you cut it out completely then change the stock size? It seems to be always off by a little bit.
Thanks
