I’ll just point out that, if your stock at least one pair of parallel sides (which is easy, if you have a tuned table saw), you only need one reference hole - and you don’t need dowels that will register it. The method I described, above, will easily position your flipped piece perfectly. For this project, I did 80 differently shaped, non-symmetric pieces with this method and it worked perfectly every time.
