Found A Random Screw
Was just about to start a job when I spotted this screw:
Could use some help figuring out where it goes.
Looks like a drag chain screw??
Check your bearing blocks on the Z axis. Not sure that is correct term, but the “cars” that ride on the “track” and have all the ball bearings inside them. Happened to me on the Z and Y.
I think it is from the bitsetter. There is an open screw hole above the wire connector. Can someone with an S5 Pro confirm there is a black oxide screw there?
Yes, there is a second screw at a right angle on the side to the one at the top.
Perfect. Thanks Will
