You seem to be missing a few settings. Here are mine (also an XXL)
$0=10 (step pulse, usec)
$1=255 (step idle delay, msec)
$2=0 (step port invert mask:00000000)
$3=6 (dir port invert mask:00000110)
$4=0 (step enable invert, bool)
$5=0 (limit pins invert, bool)
$6=0 (probe pin invert, bool)
$10=255 (status report mask:11111111)
$11=0.020 (junction deviation, mm)
$12=0.010 (arc tolerance, mm)
$13=1 (report inches, bool)
$14=1 (auto start, bool)
$20=0 (soft limits, bool)
$21=0 (hard limits, bool)
$22=1 (homing cycle, bool)
$23=0 (homing dir invert mask:00000000)
$24=100.000 (homing feed, mm/min)
$25=1000.000 (homing seek, mm/min)
$26=25 (homing debounce, msec)
$27=5.000 (homing pull-off, mm)
$100=40.000 (x, step/mm)
$101=40.000 (y, step/mm)
$102=40.000 (z, step/mm)
$110=5000.000 (x max rate, mm/min)
$111=5000.000 (y max rate, mm/min)
$112=5000.000 (z max rate, mm/min)
$120=400.000 (x accel, mm/sec^2)
$121=400.000 (y accel, mm/sec^2)
$122=400.000 (z accel, mm/sec^2)
$130=800.100 (x max travel, mm)
$131=838.000 (y max travel, mm)
$132=80.000 (z max travel, mm)
You definitely need to enter the following:
$22=1 (to enable homing)
For max travel for X and Y, I’ve seen people recommend 850 mm (33.46 inches). To get my settings, I homed my machine, then jogged to the left and forward to where I wanted my max travel to be, then used those measurements. If you do not set the max travel properly the machine may freeze after homing, depending on here the machine was on the table when you initiated homing since the default X and Y max travel settings are 450 mm.
