Hi there, when I’m in Carbide Create and try this option > Send to Carbide Motion, the file does not seem to export as no file is being loaded into Carbide Motion. It was a feature I was using all the time but then I updated to CC Build 462 and CM 618. I am able to run a cut when I import the file directly from CM but that’s just an additional step I didn’t have to do before. Can you help me resolve this issue, please?
The feature has been updated and requires matching versions.
It should work if you will update to the current betas:
Carbide Create 763:
and Carbide Motion 622:
