Hi guys.
My fusion 360 standard GRBL post processor and also the easel post processor does a weird thing (seeing as i dont have limit switches on my cnc).
When exporting Gcode from carbide create the first rapid move looks something like this: G0X100.00Y100.00Z3.00
But my fusion gcode looks like this
G0X100.00Y100.00
Z6
Z3
Z2.55
This makes the machine rapid without lifting the Z (and as my Z0 are also stock0 this presents a problem)… After that it lifts the Z to late obviously.
Easel behaves as expected also
G1 Z3.00 F228.6
G0 X100.00 Y100.00
Is there a workaround for this in fusion? Is it possible to add something in the post processor maybe? sadly both easel and carbide create arent suitable for the kind of advanced cam i need to be able to make.
I’d strongly suggest you put the homing switches on the machine - it’s required for the newer versions of cc, cm, etc, and pretty inexpensive. This makes it pretty trivial to have machine zero != stock zero. Which GRBL post are you using?
Do you turn on the router with it at Z0? Before I had homing switches, I just manually raised Z before starting a job.
You could modify the post processor, but Fusion is changing its inner workings soon. Might just wait to see how that plays out.
I wouldn’t do that unless you know what you’re looking for. I was going to suggest the post I use (modified from grbl), but it uses absolute machine references. Without homing switches, you’ll be asking for trouble worse than scraping the surface at Z0.
