I have a fixture plate with several counter bore holes molded for a friends new tormach 24r but in cam Fusion either plunges past the counter bore and cuts the hole first then cuts the counter bore.
I need it to cut the counter bore then finish the through hole before moving to the next hole.
I got close but it will cut the through hole then bore but the next hole it swaps and cuts the bore then the hole and it’s got me scratching my head.
any help would be great I added containment boundary to do the holes in sets.
No matter how I try it does hole then counter bore but when it moves to the next hole it does the counter bore then hole and switches with each hole. I’m lost
