Here is a Noob question.
I am learning to use Fusion with my Shapeoko Pro and it is cutting past the bottom of my workpiece. I have checked my stock thickness in Fusion and the zero on my z. I have even offset my z higher than the stock height and had the machine cut deeper on the second part. Not sure if there is something I am missing in the program or the machine? I would hate to have to use a spoiler board for every setup.
One thing to note Carbide warrantied my entire z axis assembly due to wiring issues. So this is not the machine losing its z setting during operation.
Anyhow any advice would be helpful.
Do you have extra stock set in your Fusion setup?
Where is your WCS origin in Fusion?
Found that menu and it looks like it maybe adding 1mm extra stock as the preset!
I will try to change this on my next round of machining,
