Don’t post process the ‘Setup’. Open the Setup and multi select the two tool paths. No Issue doing it that way. Just did it this past weekend when I had the same issue.
I have only the two paths selected. I have been doing it this way for a year. The two paths I have selected have only the 1/4 inch Bull nose in use. I get the error having ONLY those two paths selected.
The reason I tagged @neilferreri in the initial post is that I use his PP and suspect there might be an incompatibility with the new rules and his PP. I have not tried yet but I suspect using the stock PP might work but I like his and wanted him to know of the potential issue,
Of course the potential of my doing something wrong is definitely something to consider.
Given the option of using the stock PP and just running two files I will just go with two files until I hear back from Neil.
@DanSexton Unfortunately (or fortunately?), I am currently immune to the major Fusion changes. As a CAD educator, I get to keep those features.
As far as I know, all of the changes they made were to the intermediate CAM (prior to post processing). The posts shouldn’t be affected.
That said, I’m downloading your file now to see if I notice anything.
Using your PP for single paths works fine except they acknowledged that adding the line:
"(When using Fusion 360 for Personal Use, the feedrate of rapid moves is reduced to match the feedrate of cutting moves, which can increase machining time. Unrestricted rapid moves are available with a Fusion 360 Subscription.)
to the .nc as a single line broke some senders like CNCjs. They are working to fix this. So for now I have to create single file paths and edit each one before they can be used.
