Hi All,
I have a Shapeoko XXL and am using Fusion 360. I’ve tried this several times with the same result: I set zero at the bottom left corner of the piece in Carbide Motion, the same place I set it in F360, and hit start. It’s almost like the machine’s orientation is upside down and it believes the bottom left is the top left, because it starts milling below the piece. In this case since the piece is taped near the bottom of the machine, it’s actually milling in the air.
The work coordinate set up appears to be correct in F360: https://ibb.co/pQCfrLG
