Hey Folks-
I have a Shapeoko 5 pro (2x4 size). I use Fusion 360 for my CAM and was using my Macbook to run Carbide Motion, and recently decided to try out a Fusion 5 tablet instead. During the machine configuration on the tablet, the machine initialized correctly and found the Bitsetter in the usual front right corner.
When I loaded the .nc file using the Fusion 5 tablet, the machine went to the back right corner after being prompted for a tool change. The same file worked fine when I used my Macbook.
I deleted Carbide Motion and set things up again on the tablet with the same response. Any idea why this is happening? I even thought to rotate the tablet upside down to see if that was causing problems ![]()
Thanks much!
