Fusion says my machine time should be 5 Mins and the actual run time is 10 mins. no tool changes 6 operations. Are there settings for the Rapid movements that are default in CM? Any thoughts on how to get closer estimates
My understanding is that the accuracy of this estimate will be improved by a machine settings file — which one have you specified?
i usually dont select a machine in Fusion is there a settings file that i can use
Shapeoko 3 standard
ok i got it figured out
thanks
