I am about to use feeds and speeds from this chart
http://community.carbide3d.com/uploads/default/original/2X/0/0e65e6d346b92b71ce0b7211e3f734823b256d9a.jpg
Working on g10, the chart says
Depth per pass: 0.09 inches
Feed rate: 60 inches/minute
Plunge rate: 28 inches/minute
I thought those sounded pretty high, and after doing an air run, it looks a fair bit faster than I would expect with g10.
That said manually drilling through the material is super easy so maybe this is right.
Are these feeds and speeds alarming to anyone? or am I good to go?
